Configure Survey123 Install to work with ALL Users
415
10-17-2021 07:55 PM
Status: Open
SalmanAhmed21
New Contributor II
The silent install method works, but only for the user that actually runs it and not all users. Please provide an option for users to select "Install for all users" like pretty much every other app there is  - including other ESRI products. Perhaps set the default location to utilize Program Files instead of symbolic user link.
Tags (1)
3 Comments
abureaux
Was just thinking about this today!
Even having the desktop app check for updates and auto-update would be nice...
EricPescatore
I would personally like to understand why ESRI is installing the program (Survey123 Desktop) into a NEW FOLDER that doesn't exist with the USER>USERNAME>Applications>ArcGIS>Survey123. And not installing this into the more common area of the C:/Program Files.
The fact you could (at one point) install Survey123 Connect w/o administrative rights go against our company policy. I had assumed the same was for the Survey123 Desktop App.
One can only assume the location was chosen for "reasons" which I would really like to understand.
But I totally agree with the original post that more install options should be supported, especially if you want to consider the Survey123 Desktop app and "enterprise-level" deployment.
DarrylAlbert
Installing Survey123 in an enterprise environment would be great so that I can create a survey project and someone can go in and make changes and re-publish.  As it stands, surveys can be completely lost on a personal machine or if a user leaves the company.
