I want to configure the marker of the inbox map, so I can give them a color when the survey is filled. For example: Make markers yellow when field "Riskclass is NULL", Red when "Riskclass = high" and Green when "Riskclass = low".
When my inspectors are in the field they want to see at a glance what is done and what's not done. If the size of the markers can be changed the problem of overlapping markers can be solved too pleasesupportmyidea
