Just looking for the ability to have a field, similar to a photo field, that instead is pressed and a message can be recorded. Later, once back in the office say, a speech to text software could be used on the field. A witness statement, or a condition assessment report for instance.
Or perhaps it is a bird sighting app and you want to record the bird call, for later playback.
An audio field type already exists in Survey123. https://doc.arcgis.com/en/survey123/desktop/create-surveys/xlsformmedia.htm#GUID-46407E75-8E4C-4465-...
As noted, the audio question type is already available
