Bring Time Widget on S123 Web Survey Into Parity with S123 Mobile App
208
03-26-2025 03:48 PM
Status: Open
LeviCecil
So I have an sde table in Enterprise 11.3. It is registered and published in our Enterprise Portal. I've created a survey in S123 connect from the table. The problem I'm running into is with a time-only field. The time widget in the S123 iOS app records the time as hh:mm:ss in the sde table. The web version only records time as hh:mm, and I can't submit the survey because this results in an invalid ISO formatting (the lack of seconds). I don't care about recording the seconds in my survey, but I want to be able to submit from the app or the web and not have this issue come up. I'd like to keep the date and time fields separate. Not sure if this is a bug or something that should be an enhancement.
