I'd like to ask that Ersi redesign how the basemaps in Survey123 work.
ArcPro - Share - Mobil Map package should export points, lines, and polygons, NOT THE BASEMAP.
It would be great if the basemap in Survey123 were an option and then overlayed the points, lines, and polygons map package.
THEN what I hope would happen is that the software would download the points, lines, and polygons map package to the device automagically, so the inspectors don't have to sideload the data for offline work. AND then this layer wouldn't need to be connected to Wi-Fi to show up even if the basemap won't.
The sideloading process takes time, and on-the-clock time is expensive. Many thanks for considering my request.
