(Implemented) Auto update Survey123 Connect for ArcGIS
4447
14
09-21-2017 04:40 PM
Status: Implemented
AndrewHansford
Occasional Contributor II
Hi there,
I get quite frustrated with having to uninstall and then reinstall Survey123 Connect for ArcGIS every time there is an update, it would be great to have an auto update process for this.
Cheers
Andrew
14 Comments
IsmaelChivite
Idea status changed to implemented. You can now download Survey123 Connect from the Microsoft Store. If installed from the store, you will receive updates and be able to upgrade the app similarly to other Windows apps. Thanks all for your feedback and patience.
IsmaelChivite
Status of this idea changed to implemented.
Survey123 Connect is now available for download from the Microsoft Store. If you install Connect from the store you will get the usual upgrade notification and install/upgrade experience as with other Windows app. Thanks for your comments and patience.
IsmaelChivite
Status changed to: Closed
Thanks all for the idea.
As of version 3.13 you no longer need to uninstall Survey123 Connect before you can install an update.
New-version notifications are now handled through the Microsoft Store notification system.
IsmaelChivite
