'Analyze Survey' feature incorrectly identifies 'form_title' when 'generated_note_form_title' is set
418
12-19-2023 08:50 AM
Status: Open
abureaux
MVP Frequent Contributor
When using 'Analyze Survey' while form_title is empty but you are using generated_note_form_title, you receive this result:
While you can enter anything into the form_title field, it can create a confusing mismatch if you update the generated_note_form_title but forget about the form_title and someone else reviews the document.
'Analyze Survey' should detect your title in either location.
