Allow Viewers with "View and Export Data" the ability to Export Survey
3460
13
08-23-2023 12:22 PM
Status: Open
RyanBohan
I have users in the group added to be able to View Survey results, with the ability to "View and Export Data".  Only they get the error "You do not have permission to perform this action. Required privilege: create content."
Checking the Sharing settings, they have the correct permissions in the survey to export, "View and export data".  Only that is not true, it appears they also have to be a Creator.
Unless I am missing something they are not creating anything in AGO/Portal just downloading the data.
  • Perhaps an asterisk should be added that Creator is required to download content locally.
  • Or remove the Creator requirement and anyone with permission to View and export data, could do so.
I found this useful chart, only we would rather not have to bump a user looking to export data from a survey to a Creator.  Are creator licenses are limited.
13 Comments
DougBrowning
This was posted back in 2019 it looks like  https://community.esri.com/t5/arcgis-survey123-questions/export-data-in-survey123-as-a-non-creator/t...
This happens to me a lot when using the Export button in AGOL on a layer.  The issue is the way AGOL does it.  When you export it creates an item, then you download that item.  That is why it has to be a creator.   I think I have seen this posted in AGOL board a few times but cant find it.
That means this is a AGOL issue not a 123 issue and I am not sure they can do anything about it.
Looks like it used to even need publisher
BUG-000120077 Unable to export data from Survey123 website when logged in as a member having 'User' Role and ‘Creator’ User Type.
I think you would have to get AGOL to change its rules so you can try posting there.
Not what you want to hear but I hope it helps.
RyanBohan
Hi Doug,
Thank you for the thoughts.  As far as I can tell when you export from the Survey123 Website using the Export dropdown.  It does not create a layer/table on AGO/Portal.
I fully get what you mean if you're using the Export Data directly on a feature layer, however the Survey123 Website, seems to handle things a little differently.
Export changes to Exporting...
Next a file shows up locally in your machines default download folder.  (no need to specify a path/name, it just shows up)
While ideally, I would like anyone classified as a viewer to a survey to be able to View and Export data.  As the radial button implies, if that is not possible, adding a note that exporting requires Creator User type, would be super helpful.
erica_poisson
I agree that if the data is shared with you in a group, any group member regardless of user type, should be able to download the data to use locally. This should NEVER require a Creator-level account.
RyanBohan
It came about, from setting up a survey for a department, and got a list of five viewers that wanted access to the results.  And I told them the Survey share was configured so they could all now view and export the data
As they are not creators, when they tried to export, they could not.  Which means we had to rethink how they would be able to export the data and share within the group.
Eric_Andersen
Great idea, @RyanBohan, you outlined perfectly the issue.
I would like to see this functionality in place so that we do not have to use up Creator roles for users who only conduct field work.  I'm surprised there has been no input from Esri on this issue, other than the notes from the post in 2019.
A workaround is to bring survey results into PowerBI and give users access to the PowerBI report.  We try to avoid the Survey123 web data interface as much as possible.
WarrenMedernach
This has been an issue forever, and really is silly that a user is required to have Creator>Publisher to be to Export survey results.  This is a very limiting factor for our organization and as a result people  are actively investigating other options for field survey collection.
jeffhyderBRVA
I am really frustrated with this as well. It is very misleading of even having the option to share the results but fail to mention that a Creator type is required. Also, it is a mighty big jump and costs from $125 a year to $700 a year to give my members in my organization this feature. I understand that the Creator use type comes with many other benefits but most viewers do not need or want the added benefits. They just wanted the ability to export the results from the survey I had created for them. It is as well extremely difficult to get the buy in from the departments when I sell them on purchasing 5 Viewer licenses at a cost of $625 but oh if you want to export the data it will be a total of $3,500.
jeffhyderBRVA
This is what is misleading:
That should say Creators!
jeffhyderBRVA
Thanks to Jessica White at ESRI she gave me an idea on how to allow my users without being Creators on how to download the Excel data.
First go into your feature layer (hosted) that you wish to share into the settings and make sure to check allow users to "Export Data"
Second add a table element of the feature layer into your dashboard.
Third go into the settings and general tab of that element and make sure to click on "Source data download"
Fourth save your changes.
Now when you open your newly saved dashboard in that element that you chose to add a table to. Now, there is an arrow pointing down that your users can click on and download your Excel data.
DougBrowning
@jeffhyderBRVA  For Excel take a look at ArcGIS for Excel.  You can connect to the service directly live time.  No need to download anymore.  My guess is no special license needed either.  Can add maps and even edit with domains in Excel.
