Adding compass and direction readings as an attribut in S123
615
01-03-2021 04:48 PM
Status: Already Offered
ThorstenHohenstrater
New Contributor III
We take measurements of our assets (poles) and use S123 very effectively. One of the field staff asked to see if using the device inbuild compass as a possible spirit level tool and read the values inside S123;  ie need to calculate pole lean.
2 Comments
thank you @IsmaelChivite , this is great! Would it be possible to calculate the lean of the Pole in the current version? What i understand from your Bog it is the direction of the lean only, but not the magnitude.
i.e. now i am able to capture in which direction of the leaning pole ie 227deg, but not the actual pole lean i.e. 30deg. I would like to know the unit vector. S123 now had the ability of ϕ, but i was also looking at θ at an attribute. Hope this makes sense.
