Survey123 should allow custom search mode for a custom Geopoint map. It’s enabled in Dashboard when a survey is embedded but not in Survey123 apps.
A typical mobile device does not have the GPS accuracy to locate an individual within a 4'x10' area (in this case, a grave lot). Allowing the survey participants to select a known feature and pan/zoom to its location would improve the accuracy of the Geopoint collected.
