Updating the media folder of a Survey123 Form item
30839
85
12-07-2017 09:06 PM
by Anonymous User
Not applicable
16 85 30.8K
We often get requests from people who want to update a file in the media folder of a Survey123 Form item but do not want to have to re-publish their survey every time they make a change to the file. For example, the file could be a large CSV containing address information that is constantly updated from another source, and is part of an external choice list in your survey. Or you may have several image thumbnails or audio files used in questions in your survey that need to be updated regularly. Currently the only way to update these files in your survey is to update (copy and paste) the file into the media folder for that survey on your computer, and re-publish the survey via Connect.
In this blog, I will describe a technique for updating the media folder using a Python script and how to use Windows Task Scheduler to run the Python script at a regular interval. The script will connect to ArcGIS Online or Portal, download the survey Form item, extract the zip file to a folder, copy the updated media folder files from a known location into the extracted folders, zip the Form item back up again, upload it to ArcGIS Online or Portal, resulting in the Form item being updated. Users of the field app will need to delete the survey from their gallery in the field app on the device, re-download the survey from the Download Surveys menu, open the survey and they will have access to the updated survey and associated media files.
Below are instructions so you can configure the Python script with your own survey and media files.
Configuring the Python script
The script requires Python 2.7 or above to run and the 'ArcREST' Python module to be installed. If you have ArcGIS Pro or ArcGIS Desktop installed, then Python 2.7 or above should be installed, however you will likely not have the ‘ArcREST’ module. Either way, you can simply install Python and then the 'ArcREST' module as follows:
Once you have Python and 'ArcREST' installed, you need to configure the script as follows:
  1. Download the updateMediaFolder.py script from ArcGIS Online, extract from the zip file and save to your computer. Copy the updateMediaFolder.py script to your working directory (download_folder) where you will execute the Python script from; this folder will be where the temporary folders and files will be created to update the media files in the Form item each time the script is run.
  2. Edit and save the “User Parameters” section in the updateMediaFolder.py script as follows:
itemID = ItemID of the Form item you want to update
download_folder = Local folder where the Form data will be downloaded (include a / at end of path)
updated_file = Updated file name (ie MyList.csv)
source_loc = Folder path of the updated file (include a / at end of path)
portal_url = URL address of your ArcGIS portal
credentials = ArcGIS user credentials to authenticate against the portal (NB: case sensitive)
security_type = ArcGIS portal security type (LDAP, NTLM, OAuth, Portal, PKI)
Once the above user parameters have been updated in the script, save your changes and you are ready to go. Simply execute the script and the Form item of your survey will be updated.
Please note that updating the itemsets.csv file directly in the Form item via this script does not update the values in the external_choices sheet of the associated xls workbook. It only updates the generated CSV file in the media folder. If you open the survey in Connect again, or download the survey to Connect from AGOL after you have manually updated the itemsets.csv with this script, there will be a difference between the external_choices sheet in xls workbook (original values) and the itemsets.csv (new values). If you re-publish the survey via Connect again without making any changes to external_choices sheet, the itemsets.csv will be replaced with the original values that are in the external_choices sheet.
If you want to schedule this script to run regularly to update your Form item, the following may assist in getting that set up.
Scheduling the script
Windows operating systems include a simple utility called Task Scheduler. Once you have determined how often your media files change and at what interval you need to update the media folder, you can repeat its execution using Task Scheduler. For example, every 60 minutes. Obviously, the computer where you have setup the task will need to be running all the time and set to run regardless of who is logged in.
The configuration of tasks in the scheduler are pretty much self-explanatory, but here are some specific instructions that can save you some time:
  1. General: Check the option to run with highest privileges and set the task to run even if you are not logged-in.
  2. Triggers: If you want to quickly test your task, you can simply select your task in the gallery and then hit Run in the Selected Item panel on the right. When configuring the task for real, I suggest you select the startup trigger and that you also configure the task to run indefinitely.
  3. Actions: You will need to be particularly careful with this one. The Program/Script setting needs to point to the Python executable.
  • If using Python from ArcGIS Pro, it will be under the Pro installation directory. For example: C: \Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\python.exe"
  • If using your own copy of Python, refer to the installation directory of Python.
You also need to indicate and pass the location of your updateMediaFolder.py script as an argument. Do not forget to include the .py extension in the path. Lastly, set the 'Start in' property so it points to the directory in which you are storing the updateMediaFolder.py file.
Beyond the basics
The technique described in this blog post is simple but effective and will enable you to update files in the media folder of your survey without having to re-publish via Connect. However, please note that all care should be taken to ensure the files you are updating with this script have the exact name as the files in the originally published media folder. Also, the files should have the same format, with the same field names as the original files (in the case of CSV files). Only rows of data should be updated or additional rows added. If you want to change the format of the files (rename or add columns) you should update the files via Connect in the media folder, update the survey xls form, and then re-publish the survey to ensure the changes do not break anything.
It is recommended to test the script on a backup copy of your survey and ensure the survey can be downloaded and updated in the field app, checking that the external choice lists and/or media items are working as expected. This should be confirmed before running the script and updating the media folder and files on your real survey that is currently in use by other Survey123 field app users.
85 Comments
CuartaOportunidad_Local_IVC
Hi All!, I have a question
Currently, I am using the following python lines to update a form. What I want to update the most is the media file of it, so I the survey can do the pulldata of the new registers.
I run this lines:
#Getting the survey Item I will update
org_gis = GIS('my_http', 'my_user', 'my_pswrd')
srv_to_update = org_gis.content.get('srv_to_update_id')
#The path of the survey, with the new media file
path = ".../ArcGIS/My Survey Designs/survey.zip"
#Update
srv_to_update.update(data = path, item_properties={'type' : 'Form', 'title': 'survey', 'tags' : []})
I get
True as output.
However, when I go to the "updated" survey in my portal the pulldata of the new registers is not working.
Any clue of why is this happening? Should I include another parameter in the update function?
Thank you all in advance!
Regards!
RDIApps
I apologize in advance if this has been covered in this thread already, I did search it and didn't find an answer.. I have a need to use this script and currently have 10.6 installed and the py2.7 version that comes with that. I installed pip and installed the arcrest package, I can import that fine, but can't import arcresthelper.. Tried a pip install arcresthelper and that didn't work. Suggestions? probably something simple I am missing here?
Thanks!
RDIApps
Found this thread: https://community.esri.com/thread/166523
Seems like my pip install arcrest did not work as intended? This is what my site-packages folder looks like..
JamesTedrick
Esri Esteemed Contributor
Hi Luisa,
The code looks correct.  Can you verify what the name of zip file is?  When updating, it should be the same name as it was initially published as.  You could find this out from the item's 'name' property.
Dear James,
I did new proofs and I found that the survey is in fact updated, but the pulldata does not work in Survey123 Navigator. It does work for Survey123 DeviceApp and the DesktopApp.
I wonder why.
Thanks in advance for your answer!
Sofia
JamesTedrick
Hi Luisa,
You are indicating that the pulldata is not being updated in the Survey123 web app, correct?
Yes, that is what is happening
Actually, I do not know if it is not updated or if somehow when using the Survey123 web app the updated media folder is unread. Because using the other apps, Survey123 Connect and Survey123 in a movil device I have the updated pulldata information.
CoryBolen1
Philip Wilson‌ or James Tedrick‌:
Apologies if this has been covered.  I skimmed thru the previous threads, but nothing got me any further as my python skills are limited.  I am trying to run the above script specifically to update a media file folder within S123 as intended.  I defined my user parameters, the script is saved in my specified download folder, the updated .csv file has the same name / format as the original and I downloaded the ArcRest module.  I have Python 2.7.16 and ArcGIS 10.7.1 installed.  I tried running the script both within IDLE and Python window within ArcCatalog / ArcMap.  I get the following error:
...Starting
...Authenticating
...Querying
File "C:\S123_Download\updateMediaFolder.py", line 105, in <module>
   zipFileName = serviceInfo['name']
KeyError: 'name'
Below are my defined user parameters minus AGO credentials:
Any thoughts on where I am going wrong?
JamesTedrick
Hi Cory,
That's fairly unusual - that error would indicate either the login did not succeed (perhaps check the userName / passWord values, which you did not include above for obvious reasons) or the form item doesn't have a 'name' property (which all items should have).
CoryBolen1
Hi James - Thank you for your reply.  I confirmed the AGOL credentials and the form item ID are correct in the user parameters.  The form does have a assigned name (Ark_DailyOpsLog_20191106) which I wouldn't think would cause any problems.  Is the 'Name' property something different than what I name the actual form in S1223 Connect?  If so, how would I check this?
JamesTedrick
The 'name' property should be the same as you have in Survey123 Connect (unless you renamed it after publishing).  One thing you could try is inserting a line above line #105 that is
print(serviceInfo)
To see that everything is there.
by Anonymous User
Not applicable
Thanks for the script! Just curious, can the same process be done in Python API for ArcGIS instead of ArcREST?
Thank you!
JamesTedrick
Hi Yichi,
Yes, the ArcREST component deal with authentication and download/upload of the zip file - you can swap those out for equivalent Python API functions.
MarkEastwood
eibarra_geotec  Were you ever able to figure this out? I am getting the same 'BadZipfile: File is not a zip file' error
MarkEastwood
I updated line 112 data_url = "http://...." to data_url = "https://..." and the error went away.
by Anonymous User
Not applicable
Thank you James. I got it working in Python API. However, it looks like the data updates only shows up in the mobile app, but not on the website. Is that expected? I'm using pulldata() to autopopulate some of the form. The file I'm updating in the media folder is a csv file that the pulldata() function is reading data from.
This maybe a different issue, but I've ran into the same problem with using username type and pulldata(). I wanted to display information based on the user names used to sign in, but it would only work in Survey 123 Connect and mobile app, but not the website version.
JamesTedrick
Hi Yichi,
The csv file should be updated as well in the webform - could you try clearing browser caches to check if that was the issue?
You shouldn't need to use pulldata to get the username - you can use a field with the type of 'username' to automatically fill that in based on their signed-in credentials.
by Anonymous User
Not applicable
Hi James,
Thanks for the quick reply. Yes I am using the type of 'username' and then use the user name to pull data from a csv file. The purpose is to make the form only showing information customized to the specific user.
I've tried clearing browser, used different browsers and computers. All of them didn't work.
However, I tried to download the form to Survey 123 Connect. Without editing anything, published it gain. This time, it worked. But this defeats the purpose of using a script to auto update the csv file, since these was still manual publishing involved.
I'm not sure if there is anything else I could try. Any advice would be greatly appreciated!
EvenorIbarra
I still have not been able to solve this problem, I developed an
application with xamarín to generate the itemsets.csv file from the device,
I have a service where I update all the catalog lists that I need in the
mobile application, I update it every 30 seconds and look for changes in
the items, so I update the csv locally.
El lun., 9 dic. 2019 a las 15:45, M E (<geonet@esri.com>) escribió:
GeoNet, The Esri Community | GIS and Geospatial Professional Community
<https://community.esri.com/?et=blogs.comment.created>
new comment by M E
<https://community.esri.com/people/a00847138?et=blogs.comment.created> - View
all comments on this blog post
<https://community.esri.com/groups/survey123/blog/2017/12/08/an-alternative-way-to-update-the-media-folder-of-a-survey123-form-item?commentID=80856&et=blogs.comment.created#comment-80856>
JamesTedrick
Hi Yichi,
Just to check, after uploading the new file, can you download the zip file again and verify the new CSV file is present?  Also, the files are zipped within the esriinfo folder, correct?  This is important to make sure the resources the web form uses is updated.
BamJam
I ran into this issue and was able to resolve it by removing the request to be returned in json format.  So, change the url in the request:
Original line: data_url = "<portalurl>/<webadaptorname>/sharing/rest/content/items/{0}/data/?f=json&token={1}".format(itemID, agol_helper.token)
New line: data_url = "<portalurl>/<webadaptorname>/sharing/rest/content/items/{0}/data/?token={1}".format(itemID, agol_helper.token)
by Anonymous User
Not applicable
Hi!
I am also one of the folks that had trouble with the "bad ZIP file" error using this script with ArcGIS Enterprise, but after a few modifications, I was able to get it to work! I'll drop the full code into this comment, but to summarize the changes:
* Replace references to arcgis.com with portal_url variable
* Added James Tedrick's alternate zip file write function
* Removed f=json from data_url
* Added exception in uploadFile if security parameters were invalid (currently it just prints a message and tells you it was successful even though it was not)
I also had to make a configuration change to my Portal. In portaladmin/security/config, I had to change "disableServicesDirectory" in the security configuration from true to false. When it was disabled, I was getting the bad ZIP file error like everyone else, but when it's enabled, the process runs successfully. Can anyone tell me why this is happening? I'd like to leave the services directory as a security best practice, but I also need this process to work to accommodate our business needs.
Also, with the new version of Survey123, you get an update notification next time you open the app. Once the script executes, the top of the screen on Survey123 will say "Updates available: 1" and you can tap that to refresh the survey! It is no longer necessary to delete/re-download the survey.
Here's the updated code!
# Name:        updateMediaFolder
# Purpose:     Update the contents of the Media folder of a Survey123 Form item
# Author:      Philip Wilson, Esri
# Created:     04-Sep-2017
# Copyright:   (c) Esri 2017
# Licence:     Apache 2.0
import ago
import urllib
import urllib2
import zipfile
import shutil
import os
import json
import arcrest
from arcresthelper import securityhandlerhelper
# User Parameters
# ItemID of the Form item you want to update
itemID = "XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX"
# Local folder where the Form data will be downloaded (include a / at end of path)
download_folder = "C:/Temp/"
# Updated file name (ie MyList.csv)
updated_file = "XXXXXXXX.csv"
# Folder path of the updated file (include a / at end of path)
source_loc = "C:/Temp/"
# Address of your ArcGIS portal (ie https://myportal.domain.com/webadaptor)
portal_url = r"https://www.arcgis.com/"
# ArcGIS user credentials to authenicate against the portal (case sensitive)
credentials = {'userName' : 'XXXXXXXXXXXXX''passWord' : 'XXXXXXX'}
# ArcGIS portal security type (LDAP, NTLM, OAuth, Portal, PKI)
# You may need to change additional parameters in the uploadFile function depending on the security type
security_type = "Portal"
def getServiceDefinition(tokenitemID😞
    '''Gets the JSON representation of the service definition.'''
    response = urllib.urlopen(portal_url+"/sharing/rest/content/items/{0}?f=json&token={1}".format(itemID, token)).read()
    serviceInfo = json.loads(response)
    return serviceInfo
def downloadFile(urlfilename😞
    print ("...Downloading")
    req = urllib2.urlopen(url)
    with open(filename, 'wb'as fp:
        fp.write(req.read())
def extractZIP(filename,folder😞
    print ("...Extracting")
    zfile = zipfile.ZipFile(filename)
    zfile.extractall(folder)
def uploadFile():
    proxy_port = None
    proxy_url = None
    securityinfo = {}
    securityinfo['security_type'] = security_type
    securityinfo['username'] = credentials['userName']
    securityinfo['password'] = credentials['passWord']
    securityinfo['org_url'] = portal_url
    securityinfo['proxy_url'] = proxy_url
    securityinfo['proxy_port'] = proxy_port
    securityinfo['referer_url'] = None
    securityinfo['token_url'] = None
    securityinfo['certificatefile'] = None
    securityinfo['keyfile'] = None
    securityinfo['client_id'] = None
    securityinfo['secret_id'] = None
    upload_file = download_folder + zipFileName
    shh = securityhandlerhelper.securityhandlerhelper(securityinfo)
    if shh.valid == False:
        raise Exception(shh.message)
    else:
        portalAdmin = arcrest.manageorg.Administration(securityHandler=shh.securityhandler)
        item = portalAdmin.content.getItem(itemId=itemID).userItem
        itemParams = arcrest.manageorg.ItemParameter()
        itemParams.filename = upload_file
        res = item.updateItem(itemParameters=itemParams, data=upload_file)
print ("...Starting")
# initialize the portal helper class
# ago.py is part of the 10.3 python install
agol_helper = ago.AGOLHelper(portal_url)
print ("...Authenticating")
# login
agol_helper.login(credentials['userName'], credentials['passWord'])
print ("...Querying")
# get the name of the zip file
serviceInfo = getServiceDefinition(agol_helper.token, itemID)
print ("Zip file name: " + zipFileName)
# download the zip file
data_url = portal_url+"/sharing/rest/content/items/{0}/data/?token={1}".format(itemID, agol_helper.token)
download_file = download_folder + zipFileName
downloadFile(data_url, download_file)
print (zipFileName + " downloaded to: " + download_folder)
# extract the contents of the zip file
extractZIP(download_file, download_folder + "extract/")
print (zipFileName + " extracted to: " + download_folder + "extract/")
print ("...Updating")
# copy the updated file into extracted Media folder, overwite existing
source_file = source_loc + updated_file
dest_file = download_folder + "extract/esriinfo/media/" + updated_file
shutil.copyfile(source_file, dest_file)
print (updated_file + " updated to: " + download_folder + "extract/esriinfo/media/")
print ("...Cleaning")
# delete the downloaded zip file before create new zip file
os.remove(download_file)
print (zipFileName + " deleted from: " + download_folder)
print ("...Compressing")
# compress the contents of esriinfo into a new zip file
zf = zipfile.ZipFile(zipFileName, "w")
os.chdir(download_folder + 'extract')
for dirname, subdirs, files in os.walk('esriinfo'😞
  for filename in files:
    zf.write(os.path.join(dirname, filename))
zf.close()
os.chdir(download_folder)
print (zipFileName + " created in: " + download_folder)
print ("...Uploading")
# upload the zip file to ArcGIS portal
uploadFile()
print (zipFileName + " uploaded")
# delete the updated zip file after upload
# delete the extracted esriinfo folder
shutil.rmtree(download_folder + "extract/")
print ("/extract/ folder deleted from: " + download_folder)
print ("...Finished")
# final successful print message
print (zipFileName + " successfully updated with " + source_file + " and uploaded to your ArcGIS portal!")
LeeIrminger1
I am following the method by @CuartaOportunidad_Local_IVC  above- see direct link here
I am wanting to update the media folder for three CSVs that are accessed with pulldata().
The method works and changes are picked up in the Survey123 Field App on the desktop but not in the browser. The browser is only shows updates published from Survey123 Connect. Should I do something to have it update the browser? I cleared cache and ensured that it is updating with the same name as the original name of the survey. I also downloaded the survey as a zip and verified the csv reflected the change I made.
shutil.make_archive(r'temp' + 'filename', 'zip', r'surveyfolder')
path = r'zippedsurvey'
surveyitemID = "itemid"
surveytoupdate = my_gis.content.get(surveyitemID)
surveytoupdate.update(data = path, item_properties={'type' : 'Form', 'title': 'filename', 'tags' : []})
thank you!
ClintBoaz1
I am attempting to run the script but am getting the following error message despite having installed the arcrest module.
I am relatively new to python and am also confused by portal as I don't believe I have used or set up portal and was hoping to go the AGOL route as was mentioned in the explaination: "The script will connect to ArcGIS Online or Portal...upload it to ArcGIS Online or Portal".  Are there other edits that need to made to the script tp run through AGOL (like line 37 - "ArcGIS portal security type")/ what should be listed as the portal_url?
Could a portal/AGOL connection problem be causing this error?  When I look in my python folder I do not see the arcresthelper folder...  despite having done a pip arcrest install.
My user parameters:
# User Parameters
itemID = "c2c2ab0e33aa4b518c4233bbed870c20"
download_folder = r"//nwshfp01/arcgis/data/workingmapdocs/clint/forjarrod/output/"
updated_file = "SiteInventory_SQLTableDownloadTest.csv"
source_loc = r"//nwshfp01/arcgis/data/workingmapdocs/clint/forjarrod/output/"
portal_url = r"https://gdrcnw.maps.arcgis.com/home/index.html"
credentials = {'userName' : 'Cboaz_gdrc', 'passWord' : 'False55cape!'}
Any help would be greatly appreciated.  Also, thanks for writing and making this code available.  This is exactly the process I need to automate!
ZacharySutherby
Hello @ClintBoaz1
The Survey123 team has been working on updating the script to use Python 3 and the ArcGIS API for Python as that is the supported replacement for the arcrest module.
I have a copy of the updated script in another Esri Community comment that is intended to replace this script.
We are working on creating a central hub and documentation for a number of Python scripts the Survey123 has, but unfortunately isn't live just yet. Once that hub goes live we'll be updating the existing blog posts with the updated resources.
The updated script attached to the other Esri Community comment takes 6 variables. They are:
  • portalURL - The URL for your ArcGIS organization (in your case: https://gdrcnw.maps.arcgis.com)
  • username - Your ArcGIS organization username (ex. gisadmin)
  • password - You ArcGIS organization password (ex. gisadmin1)
  • itemID - The item ID for the ArcGIS Survey123 form item in your ArcGIS organization (in your case: c2c2ab0e33aa4b518c4233bbed870c20)
  • updated_files - The updated file name containing the extension (in your case: SiteInventory_SQLTableDownloadTest.csv)
  • source_loc - Folder directory where the updated file is located (in your case //nwshfp01/arcgis/data/workingmapdocs/clint/forjarrod/output/)
The script will need to be run either in Jupyter notebook which ships by default with ArcGIS Pro, or can be run directly in ArcGIS Online if you have notebooks enabled for your account.
Thank you,
Zach
DataOfficer
Hi @Anonymous User ,
I am trying to use this script but it fails at the first hurdle.
  File "C:\Users\rob.ward\Desktop\updateMediaFolder.py", line 10, in <module>
    import ago
ModuleNotFoundError: No module named 'ago'
I expect this is something fairly straightforward.
I am trying to run the script using IDLE ArcGIS Pro 3.7.10.
Thanks
ZacharySutherby
Hello @DataOfficer
The script in this blog is quite old and is intended for ArcMap the modules used by the script have been superseded by the ArcGIS API for Python.
We have updated this script to use the ArcGIS API for python and the updated script is present in our Survey123-tools github repo
Thank you,
Zach
DataOfficer
Hello @ZacharySutherby
Thank you. I've now downloaded the updated script and it appears to be running correctly. I just had 1 query. Is the following still true?
We are updating the media folder contents regularly (weekly if not daily in some instances), and so asking our users, many of whom are volunteers, to log in, delete the survey from the field app, and re-download it prior to every survey is an extra step they could do without. If there is a way to update regularly without the need to delete and re-download the form it would be very useful.
Many thanks,
Rob
ZacharySutherby
Hello @DataOfficer
That statement is no longer relevant, since the 3.9 release of ArcGIS Survey123 an update notification system was implemented. After the media folder is updated Survey123 will recognize that the form item has been updated and display a notification that an update is available.
In Survey123 Connect under the options you can enable "Require update to the latest version of this survey" so that when someone selects the survey they will need to update it before starting a survey.
Thank you,
Zach
DataOfficer
Fantastic @ZacharySutherby , thank you for clarifying.
StrathconaBTS
I created an alternate way to do this with Portal/Enterprise without requiring a server or python. ESRI already works with Integromat. I was able to keep a CSV in the media folder updated by executing an Integromat scenario every day at a specific time. The CSV populates a select_multiple_from_file field. I used REST API calls to achieve this:
  1. Get your auth token - module: HTTP Make a request
  2. Download the survey zip - module: HTTP Get a file
  3. Swap in your CSV file - modules: Archive Extract an archive => Create an archive
  4. Upload the modified archive - module: HTTP Make a request
    RED is the folder ID the survey lives in
    BLUE is the user that owns the survey
DataOfficer
This was all running fine for me, but I am not getting the following error:
  File "redacted.py", line 129, in <module>
    itm.update(surveyProp,updateZip)
  File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\gis\__init__.py", line 13002, in update
    ret = self._portal.update_item(
  File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\gis\_impl\_portalpy.py", line 2609, in update_item
    resp = self.con.post(path, postdata, files)
  File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\gis\_impl\_con\_connection.py", line 1407, in post
    return self._handle_response(
  File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\gis\_impl\_con\_connection.py", line 900, in _handle_response
    self._handle_json_error(data["error"], errorcode)
  File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\gis\_impl\_con\_connection.py", line 923, in _handle_json_error
    raise Exception(errormessage)
Exception: The size of the appCategories cannot be more than 64 KB
(Error Code: 400)
Does anyone have any suggestions of how to overcome this?
Many thanks.
ZacharySutherby
Hello @DataOfficer
It looks like you may be using an older version of the notebook, if you navigate to line 129 in your redacted.py file there will be a line of code that says
Try switching the surveyProp variable in that update method to an empty dictionary `{}` does that resolve the issue?
From the error it looks like the size of the request generated from the update() method is very large. Typically this could be due to a very large dictionary containing the properties of the survey. While the properties are required for the update() method it can be an empty dictionary.
If the behavior still persists after switching the properties in the update() method to an empty string the issue is then likely your survey form item is very large. If it contains redundant or unused files in the media folder it may be worth considering removing them.
DataOfficer
Hello @ZacharySutherby , thank you for the rapid response. I've updated the code based on your suggestion and the latest github entry and that seems to have done the trick. Thanks for all of your help.
