Survey123 Tricks of the Trade: Working with attachments in Microsoft Power Automate (v2)
21615
35
01-17-2024 05:27 PM
IsmaelChivite
Esri Notable Contributor
14 35 21.6K
Survey123 smart forms let you record signatures, photos, annotated images and upload documents into ArcGIS. All of these are stored in ArcGIS as 'attachments'. This article describes how you can use Microsoft Power Automate to work with these attachments. Specifically to:
  • Include one or more Survey123 attachments in an email
  • Upload Survey123 attachments into Microsoft OneDrive
I will assume you are already familiar with task automation using Survey123 and Microsoft Power Automate. If so, get started by publishing a survey with an image, signature or some other question type that uses ArcGIS attachments. Then log into Microsoft 365 and create a new Automated flow with the Survey123 trigger. Follow the instructions below to learn how to work with these Survey123 attachments in Microsoft Power Automate.
Adding multiple attachments to an email
Survey123 attachments are modeled as an array. In Microsoft Power Automate, you can create an array variable and populate it with Survey123 attachments. Later you can include that array variable in your email to define what attachments should be included with your message.
Immediately after your Survey123 trigger, add the Initialize variable action. We will populate this variable later with the attachments from your survey. Make sure you set the Type to Array and set a descriptive name. Leave the initial value empty.
Next, add the Get attachment from URL action from the ArcGIS connector.  This will help you download the attachments. For the URL parameter, you will use the Dynamic content dialog and select the feature attachment URL for your question. In my case, the question with attachments in my survey is called Photos, so the dynamic content is feature attachments photo URL.
As soon as the URL parameter is set, Microsoft Power Automate will wrap the Get attachment from URL action within an Apply to each block. This is because the Photos question in the survey may have one or more attachments in it. Power Automate cycles through the Survey123 attachments using an Apply to each block.
At this moment, we are ready to populate the Array variable we setup initially with the attachments found in our Survey123 Photos question.  This is done through the Append to array variable operation and since it is the most complex part of the entire workflow, so I broke it down into two steps.
Step 1: First we add the Append to array variable action right after Get attachment from URL, and within the Apply to each block. For the Name parameter, we will select the name of the array variable we want to populate, which is the one we created at the beginning of the flow.  The Value parameter must include a JSON string so we can specify both the name as well as the actual content of the file.
The preliminary JSON string looks like this:
  "Name": <File name including the extension goes here> ,
  "ContentBytes": <File contents go here>
Step 2: To specify the correct file name and contents, we will use Dynamic content. In my case, since the question in the survey with the attachments is called Photos, the name comes from feature attachments photos name. The ContentBytes value in the JSON needs to get populated with the Attachment contents output from the Get attachment from URL action.
With the array populated with all the Survey123 attachments, we can now proceed to configure the Send Email action in Microsoft Power Automate.
Add a new Step to send an email, but make sure it gets added outside the Apply to each block. After completing the Recipient, Subject and Body parameters, expand the Advanced options
In the Advanced options you can specify the attachments that should be included in the email. Note that there is a switch button that lets you specify either a single, or multiple attachments. In our case, we want to select the multiple attachment view and then insert the value of the array we populated in there, as shown in the animation below.
Now you are set! Save and test. The workflow described above will work when you have one, but also when you have many attachments.
Adding Survey123 attachments to Microsoft OneDrive and Sharepoint
Next we will have a look at another common scenario where you might want to backup your files, or host them outside ArcGIS so they can be used with other third party systems.
If you want to upload your attachments into Microsoft One Drive, for example, you can use the Upload file from URL action. For the Source URL property, select from the Dynamic content dialog the feature attachments URL array for the appropriate question in your survey. Remember that if working against a private survey you will also need to add your token to the url (?token=[Portal Info Token]).
An apply to each block will be added automatically for you. Now all you need to do is to select the Destination File Path for your file. You can select an existing folder, or even create a new one.
In the example above, I set the Destination File Path using one of the questions in my survey. The value of my question determines the directory in OneDrive where the file will be stored. If the folder exists, it will use it. Otherwise, it will create a new one. This is an interesting concept, as it helps organizing files nicely: by ZIP
code, by case ID, by field team, etc.
A similar approach can be used to upload files into SharePoint as shown in the following screenshot:
When uploading photos into OneDrive or Sharepoint, you do not need to initialize an array variable at the beginning of the flow.
35 Comments
Tiff
EDIT - Resolved this by just putting the variable in the box and it worked perfectly.
Thank you @IsmaelChivite for this detailed workflow. In the Advanced settings step of the email, I am seeing something different from your single "Incident Photos" variable. It is asking me for the same json format as the append to array variable action as soon as I press the button "Switch to input entire array". Can you please assist?
Can I put the dynamic content Photos variable in place of the json? It says "Attachments Item" where yours says "Attachments" so I am not sure if that is the same.
AndrewThompson_SCE
I have jpg files downloading but there is no photo. Its all 2KB files. Do we need to put a token in the photo url for it to download correctly?
Edit:  Adding the token to the URL worked.
abureaux
MVP Frequent Contributor
Can't wait to try this. This has been on my list of things to do for way too long now.
Thanks again @IsmaelChivite for the detailed guide!
Tiff
Hello @IsmaelChivite, question about flows where photos are optional. The photo field I am using in the "For each" trigger sometimes does not have a photo. I used the "Run after" setting to bypass this and send out an email regardless of if a photo is included. I am still getting "Flow failed" notifications as a result. Is my approach the best way to do this or should I do a conditional of some sort? I would ideally not like to be notified of a failed flow when the email does successfully send.
Thank you! Please see screenshot example below.
RobertAnderson3
MVP Regular Contributor
Hi @Tiff
Try setting up using a Condition to check if the variable for the attachments is empty or not, then run the apply to each only if it does have content. If null, just send the email, if not null then run the apply to each.
Tiff
Thank you @RobertAnderson3! What I was missing from this was simply being able to put null down as the function/criteria. I didn't know I could do that. I've tried this and will be able to test it out soon.
RobertAnderson3
No problem @Tiff! Yeah, it needs to be added in under the Expression, it's a function in there. Hopefully it works for you!
SusanMathai
@IsmaelChivite
Hi Ismael , Please can you identify the invalid JSON error here, regardless of whatever item i choose from the list as shown in the picture below, I get an error "Enter valid json"
I appreciate all your help!
Thanks a lot.
RobertAnderson3
@SusanMathai It looks to me like you might have an extra comma in there beside the Name: section?
SusanMathai
@IsmaelChivite
Never mind I fixed the error it works perfect now.
EricBongelli
@SusanMathai and @IsmaelChivite
What was your solution for the invalid JSON error? My flow used to work (as recently as March 2024), but recently stopped working. I have not changed anything in my flow, but I do now get the invalid JSON error on the Get URL attachment step. Any ideas would be appreciated.
OussamaMerhi
Now I want to add the attachment to another feature layer using add attachment. How can i  do it
m3
I'm having the same issue as @EricBongelli
abureaux
@m3refresh your connections.
There is currently a bug that Esri is working on that may be causing you additional issues:
BUG-000169725 Authentication to ArcGIS Online through ArcGIS Connectors for Power Automate workflows frequently fails with the error message, "Authentication failed. Your session has expired."
m3
This is a brand new connection, I can try refreshing it or creating another but I get the error still so I guess I'll wait on the bug.
abureaux
That bug is only "In product plan" and the timeout is every hour.
Can you post a screen cap of the error?
If it is the same as EricBongelli and the "innerError" looks like this, that means the connection times out (like I mentioned above). In that case, refreshing the connection is the solution.
If this isn't you error message, there may be something else going on.
First thing would be to check account permissions.
If account permissions aren't an issue (e.g. you are using an Admin account), then maybe try selecting the layer you want to work with in your Portal and "Add to favourites". Then, back in Power Automate, change "My Content" to "My  Favourites" and try again. I sometimes get better results that way.
m3
"innerError": "Authentication failed. Your session has expired. Please log in again to continue."
That is my error message
abureaux
I would definitely try refreshing the connection.
  1. Click Connections
  2. If you are using Enterprise, look for the purple ArcGIS Enterprise connector.
    If you are using AGO, look for the orange ArcGIS connector.
  3. Click the ellipses (...)
  4. Click Switch account and log in using an account with appropriate permissions.
After that, try the flow again. Honestly, it should work after this. If it still doesn't work, jumping on a call with Esri Tech Support may be a good next step so they can see exactly what you have configured.
m3
That worked, I had to delete all my cookies to ensure I was switching to the correct account.
Thanks!
SaadShahzad
I've tried everything to get this method to work, but I cannot get it to work for ArcGIS Enterprise and using attachments in a repeat.
Any tips on how to get this working when attachments are put in a repeat?
abureaux
@SaadShahzadyou need to loop through the repeat. While not working with attachments, I have a guide for working with nested repeats in Power Automate. The concepts are all the same though.
The only thing you will probably need to account for is empty/null attachments. That can be achieved with a "Condition" action.
RuchiraWelikala2
We have people submitting multiple PDFs, images, zip files, etc. It worked until about 2 weeks ago but then suddenly started failing. I followed this tutorial by when it comes to sending the email, i receive the following error:
  "status"400,
  "message""No input parameters provided. Please provide required input parameters 'To', 'Subject' and 'Body'.\r\nclientRequestId: a3a4cf18-812c-4f53-a13e-084751xxxxxx",
  "error": {
    "message""No input parameters provided. Please provide required input parameters 'To', 'Subject' and 'Body'."
  "source""office365-wus.azconn-wus-001.p.azurewebsites.net"
Has anyone else experienced something similar lately?
abureaux
@RuchiraWelikala2, have you tried refreshing your Connections yet? I'd guess that they timed out. Beyond that, you may wish to make a post on the S123 forms for more detailed help.
RuchiraWelikala2
@abureaux Yes, I have. I added a trigger event all over again and reconfigured everything but still failed to work. I isolated the issue to just the array and the attachments. I created a brand new workflow using the new designer and the updated modules in the new designer and it is working now. Very strange.
NateHollenbeck
I am looking to do something similar, but I am using the trigger "When a record is updated in a feature layer". Is this possible? I am using similar steps but the workflow will not get past the "Get Attachment from URL". I am hoping to get some insight on what I am doing wrong. I have included a photo of my workflow.
gallatingis
Thank you for the detailed walk through! Is there an alternative if I do not have ArcGIS (premium power automate account)?
m3
@gallatingis
Make.com has a free tier with a limit to the number of triggers
IanGallo
@RuchiraWelikala2 The biggest downside to Power Automate is that you need to re-connect Survey123 every13 days - just by re-entering your username and password under "Connections" on the Power Automate home page. Esri's token expires every 14 days.
IanGallo
@IsmaelChivite Super helpful. I would like to use this add all images collected in a survey to a SharePoint Library. The image question I am referencing is in a related table. I can successfully add the image to the library but when I try to update the image's properties I can only successfully access attributes from the parent feature class. All fields in the related table, even though they are populated in the feature service, write as null. Any idea how to work around this?
KwabenaDenteh1
hello @IsmaelChivite  I am trying to use when a record is created connector in replace of when a survey is submitted so we use fieldmaps instead of survey 123 for the project but I am unable to get the attachment . Everything works perfect but the get attachment url wouldnt work
Austin_Schneiderman
SO, I got this flow working almost entirely, except that the attachments that come through the email are super small .jpgs (276 bytes) exactly for each attachment. Trying to preview them results in a "It looks like we don't support this file type" error. Downloading them and then trying to open results in the same. Anyone else have this issue? I haven't been able to find any articles on this.
abureaux
@Austin_SchneidermanAll your attachments are the same size and don't open? I'd be willing to bet those aren't images. Download one and open it in a text application (VS Code or Notepad++). You will likely see an error message of some sort (like "token issue", or something of the sort). That error should give you some more insight into what went wrong.
Austin_Schneiderman
@abureaux "Cannot read properties of undefined (reading 'split')" is what VS code is telling me. I'm guessing the array variable might be the culprit but it's hard to say. I am pulling these photos from survey123 responses just like the example outlined. I'll run through everything again and make sure nothing small was missed.
C_Miller
Occasional Explorer
@Austin_Schneiderman I am having the exact same issue. Were you able to find a solution?
johnchewitt77
Hi @IsmaelChivite, this post was incredibly helpful. I am trying to copy Survey123 responses from one survey into a separate survey on another ArcGIS Online. I'm not sure how to copy the attachments (in repeats) into the second survey. Could you tell me what the steps should be?
