[Updated February 29, 2020]
IMPORTANT: Check the https://community.esri.com/groups/survey123/blog/2020/02/19/upcoming-changes-to-survey123-web-forms-... blog post for upcoming changes affecting content described in this article.
Today we will explore how you can edit existing records using the Survey123 web app, also known as a web form. The idea is quite simple, we will populate the contents of a Survey123 web form using an existing record from a feature layer and let users update (edit) that information. When working this way, the submit button in the survey will update an existing record, as opposed to creating a new record for a new survey response.
This technique for editing data in a web form be quite handy. You can use it for example to let people review and modify existing submitted data, or to simply let them finish an uncompleted form. You can also incorporate web forms into QA/QC and data validation workflows.
Before we start, be aware of the following:
Editing of existing data in a web form is possible through the use of web form URL parameters. If you are not familiar with web form URL parameters in general, I strongly suggest you read the https://community.esri.com/groups/survey123/blog/2019/02/06/survey123-tricks-of-the-trade-web-form-u... first.
Here is an example:
https://survey123.arcgis.com/share/1cb28b212b5542acbbdbaa35feba0765?mode=edit&globalId=fb364524-e523...
Note the two URL parameters:
URL parameters are case sensitive. For example: globalId is not the same as GlobalID or globalID. If you see that your form is not loading the record you want, double check the spelling of the parameter, and also ensure the globalId you are trying to load exists.
As described above, the editing mode in web forms was incorporated in version 3.4. If you want to edit records using a survey that was published in the past, you can bring things up to speed in two different ways:
My recommendation is that whenever possible you upgrade your surveys by re-publishing them. It will improve the initial loading time of the survey in the web browser, and it will guarantee that the behavior of your web form remains unchanged even if the Survey123 release changes.
From a practical perspective, the technique described above is useless unless you somehow present a ready-to-use link (URL) to the end user; A link that already includes the appropriate globalId to edit. Do not expect end users to modify that globalId manually in the web browser URL address! I will next describe three scenarios to illustrate how you could apply this technique.
Our first scenario allows users to navigate a map, and launch an edit web form from the popup of an existing record. The key is to customize the feature layer popup so it dynamically generates the correct URL to launch the survey. Once the popup is configured, you can use the web map within the ArcGIS Map Viewer, custom Web AppBuilder apps, Explorer for ArcGIS and any app that supports web maps.
Here is a brief step by step guide to configure your popups:
The idea with this one is to add an embedded content element within the dashboard, and configure it to display your web form. The URL of the web form will include the mode parameter set to edit and the globalId will be dynamically populated. Using a filter action triggered by other element within the dashboard, such as a list, the embedded content element will refresh your web form with the relevant record to be edited.
At a high level, the steps are as follows:
For more details about this, check https://community.esri.com/groups/survey123/blog/2020/04/27/survey123-tricks-of-the-trade-embedding-...
In this scenario, we will use a web hook to automatically send an e-mail to the user submitting the survey. This email will contain a link for the user to complete or make modifications at any time. To do this you must be familiar with web hooks in general or with either Microsoft Flow or Integromat. Like in the examples above, the trick is to be able to dynamically populate the globalId of the record you want to edit. Luckily enough, the payload of a Survey123 web hook includes information about the user submitting the data (if logged-in) as well as responses to questions in the survey. So as long as the user is logged-in or a specific question in the survey captures the contact e-mail, you can make this work.
Here are the high level steps:
Here is some visual aid in case you are using Integromat.
If you are using Integromat or Zapier, the pattern is pretty much the same: use the webhook payload to retrieve the globalId of the submitted record and use if for your edit web form url.
