User role other than Administrator to publish StoryMaps publicly?
1151
04-04-2023 02:37 AM
NellieSofie
Are there any roles other than administrator that can publish public storymaps? It would be useful for a user in our organization to be able to do this, but there is no need for additional administrator rights.
The user is currently set with user type: Creator and Role: Publisher, but they are only able to publish the updated storymaps internally in our organization.
ChristopherCounsell
MVP Frequent Contributor
This is an organization setting where you can set only administrators to make content publicly available:
https://doc.arcgis.com/en/arcgis-online/administer/configure-security.htm#ESRI_SECTION1_323F5BC306A5...
If it is enabled, the user account will need to be an administrator or a custom role with the privilege to 'Share member content with public'
https://doc.arcgis.com/en/arcgis-online/administer/privileges-for-roles-orgs.htm#ESRI_SECTION1_41D91...
Honestly, I would recommend not enabling all members to share content publicly. Depends a lot on your organization and data, but it's generally better to have a review process in place and then transfer to a public-facing user account. A 'Toronto Hospitals Map' from 'TorontoCityCouncil' looks way better than 'Hospitals Map' by 'Nellie Sofie' when viewed by the public, etc. Loads of good blogs on this topic.
ChristopherCounsell
