Update the field used in the map as a label in the StoryMap
259
04-08-2025 11:28 AM
CatherineAtkinson
I want a different field to display when hovering over the point on the map. I have changed the popup title and label in the map to Status; however, it still shows the name. I need to show the status as part of this Story Map, but I only see that I can add 2 fields to the image. Is there any way to add any additional field information? I tried to create an expression in the field maps form to join 2 fields; however, it never would fill the fields with the information.
OwenGeo
Esri Notable Contributor
These two articles contain information about creating a new field to use as your map tour description that combines information from several fields.
Owen Evans
OwenGeo
Owen Evans
