Unable to delete empty text space in StoryMap
4023
9
08-09-2023 09:53 AM
BrittanyBurson
Here is an existing post about this but in the ArcGIS Pro community, same issue, I tried the suggestion to clear my cache but no go https://community.esri.com/t5/arcgis-pro-questions/deleting-text-space-in-storymaps/td-p/1086481
I am unable to delete this empty space in my text box and it looks unprofessional. This should be really simple but I am unable to figure out how to delete this empty space? Anyone?
OwenGeo
Esri Notable Contributor
@BrittanyBurson - I'm sorry you've run into an issue with extra space. I ran into this once and resolved it by dragging the blocks below the space to a position above it. This rearranged the blocks and pushed the space out from between the blocks.
All blocks have a drag handle on the left when you hover over them. Just grab the block and drag it to relocate.
Can you give that a try and let us know if that works for you?
Owen Evans
OwenGeo
Owen Evans
BrittanyBurson
@OwenGeo that worked, thank you very much for the reply.
BrittanyBurson
I saw this was marked as an Accepted Solution... just want to follow up reply that it's a workaround rather than a solution... should still be fixed as it's not user friendly.
JennyP
Even if it's late, or maybe you've already figured it out — but just in case, you can click on the text box and just press delete. That will remove them.
HeatherLee13
This will just move the extra space. Is there a way to actually delete the space. I have 6 headings to delete.
JennyP
ATFerguson
Are you on AGOL? I'm running ArcGIS Enterprise 11.3 and it doesn't look like the delete option is available. I suppose it's a new addition in 11.4 or 11.5 (?)
jennPp
The only thing that I do is, click on that box of text and click delete on the keyboard, and it's gone:)
jennPp
and yes, i'm on AGOL so I don't know if it works for you
