Time animation in StoryMap not working
1971
7
11-13-2022 05:01 PM
KristineHubenig
Hello!
I am working on a StoryMap  which shows the migration of people over time.  My feature layer is time enabled and I have attached  an image of what the settings look like in Map Viewer. It works great in Map Viewer, but unfortunately it does not work in StoryMaps. In StoryMap when I add my map, it shows the time slider but no dates. I have also added an attachment of this too. So when I press play it shows all locations at once and does not animate the migration. I have tried to change the settings in Map Viewer, delete and add the map back in, and it gives me the same result where it is "Enabled" but not functional.
Any help would be greatly apricated thank you!!
OwenGeo
Esri Notable Contributor
@KristineHubenig @CharmaleeSandanayake1
We have a fix for this, and it will go out in our next update on Nov 30. I apologize you have been impacted by this issue.
Owen Evans
AbbyE_Esri
Hi Kristine,
I'm sorry you're experiencing this behavior. Would you be able to provide us with a link to your story so we can take a look at the behavior? If not, please reach out to Esri Support and they can assist with additional troubleshooting.
Abby
I also see this issue with the time slider not showing up in a story map but working in the map viewer. The screenshot looks the same. I will have to disable the time animation functionality until a fix is found.
OwenGeo
We've been able to reproduce the problem and are looking to address this in the near future. We'll post an update here when we have more information.
Owen Evans
OwenGeo
Owen Evans
KristineHubenig
Thank you! Looking forward to the update.
AnninaHirschiWyss
Same here... Looking forward to November 30 🙂
OwenGeo
This issue has been fixed. Please let us know if you are still encountering issues with the time animation widget.
Owen Evans
