hello everyone! I have a problem with my story map ... I see it in my profile but it doesn't load anymore, the error is "there seems to be an issue..the story can't be loaded..why? can you help me? thanks
@taniamassa -- I'm sorry you aren't able to load one of your stories. For a specific issue like this the best way to get help is to contact Esri Tech Support.
Hi @taniamassa ,
There could various reasons that the storymap will not load, may be some of the contents are not shared correctly, could be there are items missing which were originally used to create the storymap. There could be network connectivity issues.
What I would do is try to load the storymap in the browser and open Developer tools and investigate the network requests. (Most commonly 'F12' key would open that)
If you notice that there are some pending or blocked requests it might give you some pointers to look for.
Hope this helps.
