Story Maps not loading
18824
81
05-02-2023 11:32 AM
NancyMontes_de_Soto
I am getting a blank page when I am trying to open several of my story maps. I created the story maps long ago, and in the past I had seen a sad face sometimes, but this time I am getting a blank page. I refreshed the page several times and that worked some times but not others. I am using Google Chrome. But I also tried in Microsoft Edge and Firebox - same issue. They were working fine a couple of week ago. Any help?
Tags (1)
SaraJL
@OwenGeo
We are also experiencing intermittent issues with Story Maps projects not loading! Sometimes if I clear out the cache, it will work - but the load time is definitely slow even after clearing the cache
OwenGeo
Esri Notable Contributor
@DavidNovak -- Are you seeing a white screen or an error screen when the story doesn't load?
There is a known issue we are working on addressing where if you are logged in and view a publicly shared story, and then log out and try to access the story anonymously the story will redirect to an error page for a period of time after you've logged out (until your local cache expires, about an hour).
This issue only affects the one machine where the story was viewed while logged in. Others are still able to see the story as expected. If you try to view the story in a new private browsing window (or clear your browsing data) the story would be viewable.
Does this sound like the issue your customer is experiencing?
Owen Evans
DavidNovak
Thanks @OwenGeo for fast reply.
Kind of. This StoryMap is made by our customers. I am logged in to my AGOL account, but not in their organization but in mine. The issue is reproduced for me in Mozzila Firefox, but I was never logged in Firefox.
Edit: "Now testing behavior you are describing. In Chrome I am able to reproduce your issue. After login in any ArcGIS account I am able to see the StoryMap. If I logged out from AGOL I am not able to see StoryMap no more. Is this caused by some Basemap, Custom StoryMap theme or something...?
I am not able to see StoryMap in Firefox if I am not logged in AGOL with any account. Even a free account will make StoryMap visible."
Yes, looks like this is some security, authentication problem. Please do your best, we believe in you! 🙂 If necessary you can contact me by personal message there and we can make some fast call.
David.
DavidNovak
For us, the issue was solved. Thanks, Esri!
Galen
This issue appears to be back October 6th 2023. All Story Maps are down unless you're logged in. I've confirmed in Chrome and Edge incognito browsers on desktop, and Chrome on mobile. Dev tools gives the following error: net::ERR_HTTP2_PROTOCOL_ERROR 200 (OK)
OwenGeo
Thank you for reporting this @Galen. We also detected the issue and our team is looking into it. We hope to have things working as expected again soon.
Owen Evans
OwenGeo
@Galen - We believe this has been resolved. Please let us know if you continue to experience this issue.
Owen Evans
jkennedyie
I have submitted details as a bug report but FYI the following public story map rendered as a blank white page this morning Nov 15th 2023 at least between 10:20 and 10:40 GMT. At around 10:40 it started working again as normal.
https://storymaps.arcgis.com/stories/cc31496db8194c968abf92f601539b74
Rgds/John
DawnBlanchardDoIT
We are having the same problem on 11/15/2023 but only in Chrome. https://storymaps.arcgis.com/stories/7048dee160524a2e9bdac5ea1dbba794
OwenGeo
@DawnBlanchardDoIT @jkennedyie @TimJonker2 -- Thank you for reporting this. Our team also noticed a spike in error rates in our infrastructure this morning and took measures to alleviate this.
We believe the issue was resolved shortly after it began, but please let us know if you are still able to reproduce this issue.
Owen Evans
