Hi there,
Can you share a story map to someone who is not signed up to arcgis. I'm aware that you share publicly for all to see or within an organization. If anyone knows how to share privately your help with the steps would be greatly appreciated
Thanks a mil 🙂
Anne Marie
Hi @ANNEMARIEBROWNE -- That is not possible at this time. For someone without an ArcGIS account to be able to see a story, the story must be shared with everyone.
Thank you Owen.Is there a particular type of account that they are required to be set up on? Is it a general Arcgis account?
Will the private option become available in the near future?
@ANNEMARIEBROWNE -- Any user type with view access to items in the organization is sufficient (this includes Viewer, Storyteller, Creator, and others). I'm not aware of any plans to implement a private/no-account option at this time.
I have gotten around this by publishing to the organization and providing my login info to my clients which of course Esri tells you not to do! But as a consultant, I am usually set up with a guest account within my clients' AGOL organization, so technically they already have the info.
Would the proposed, or possibly implemented, guest account logins for Enterprise work in this circumstance @OwenGeo ?
