Sharing Frame to social media
702
12-07-2025 02:13 AM
CatherineCarter1
I have been experimenting with Frames and so far I think it is going to be great for social media. However, when I try to share my Frame the only choices are FB, X and LinkedIn. These are ok but old. The new generation I want to reach are on Instagram, Threads and BlueSky. Is it possible to share a complete Frame to these? If not, is it something that might be coming soon?
Catherine Carter
ClioClark
Hi Catherine,
I would recommend upvoting the following idea to give kudos: https://community.esri.com/t5/arcgis-storymaps-ideas/add-bsky-to-social-sharing-options-allow-select...
You can also comment on the Idea to suggest that Threads and Instagram are added to the social media sharing options, as well as BlueSky.
CatherineCarter1
Hi Clio . yes, I could do that, but it doesn't answer my question. Can I add a complete Frame with the interactivity to Instagram, Threads, or BlueSky? If not, will that be added soon? Until that happens, Frames is just cute,  not useful.
ClioClark
Hi Catherine,
At present, this functionality is not available. However, as Frames is in Beta, the StoryMaps team is actively adding new features and capabilities. One of the areas they are focusing on is supporting enhanced sharing to popular social platforms.
The team have provided the following feedback form whilst Frames is in Beta, so you can provide direct product feedback as well as ideas for improvement. I would highly recommend filling in the feedback form whilst Frames is still in Beta:
https://survey123.arcgis.com/share/05a4ced7ab0a43ceb48c966c1d071f06
I hope this helps!
CatherineCarter1
It does help. Thanks, Clio.
JosephMayfield
Hi Catherine,
Thank you for sharing this feedback about frames. During the beta phase for frames, the StoryMaps team is focused on improving the options for sharing frames on popular social platforms. As a first step, in today's release, we added a new feature that enables authors to create video and PDF files from StoryMaps frames. These files can also be used to share your frame on social platforms, and in other communication channels, so viewers do not have to open a link to view the contents of the frame. More information can be found here: Create video and PDF files from StoryMaps frames
