resize the map in tour storymaps connecting feature service
1186
03-15-2021 07:04 AM
Fab_the_lab
HI,
how do I set the size of the map when I create a Storymap tour using the "start with the feature service"  function? In fact, every time the map is loaded with the maximum extension and not the regional one I need.
On the other hand, setting the extension at the feature layer level does not solve the problem.
Help-
OwenGeo
Esri Notable Contributor
@Fab_the_lab -- The initial extent of the tour should update based on the points in the feature layer. This is true as long as there are two or more points in the layer (it's impossible to calculate an extent with just a single point).
How many points are in the feature layer you are using?
Owen Evans
Fab_the_lab
hi Owen,
i have 5 points.  You only see one because they are very close. Here is a more detailed view.
Fab_the_lab
when I use the default "explorer" layout it seems to work fine, but when I use the "guided tour" layout it may not work and the map extension is not correct.
