Layers from KMZ appear in Map Viewer, but not in Storymaps Tour
9021
12
11-05-2020 10:37 AM
LisaGeiger
I've created a georeferenced image overlay in Google Earth, saved it as a KMZ, and uploaded to my ArcGIS account. When imported into Map Viewer, the overlay looks good: https://www.arcgis.com/sharing/rest/content/items/dce38dd3af6f4d6c86ec8d6eda2cd2a0/data
However, when I try to used this map as a Basemap for a Storymaps Guided Tour, the layer holding the KML data doesn't appear: Cemetery (Draft Cemetery-Focus) - ArcGIS StoryMaps
I've gotten KMZ overlays to display in other Storymap Basemaps using this same method, and I'm confused why its not working with this Map.
OwenGeo
Esri Notable Contributor
@BethanyLamb -- Hmm, I'm not seeing that KML layer when viewing your map in map viewer beta. Can you please check that again on your side?
I do see some CORS/security related errors in the console when opening your map in map viewer beta, so I do think this is an API issue, so I can try to see if our API team can have a look.
https://www.arcgis.com/apps/mapviewer/index.html?webmap=68aadb1cab1d478ea147cf518d205b60&extent=-122...
Owen Evans
BethanyLamb
You're right. I can't actually see it in Map Viewer Beta, just the classic map viewer:
MahmoudArab
I have this issue where I uploaded a KML file to my content in ArCGIS online and then I want to upload it to my story on GIS StroyMap but I cannot find it. I only find an old map which is web map.
Could you please help?
