Larger Pictures in Sidecar Panel
607
04-13-2020 09:55 AM
michael_vetter
I'm adding pictures in a sidecar panel and the pictures are kind of small. Is there a way to make the pictures larger or to pop the pictures out when a user clicks on them?
Michael
OwenGeo
Esri Notable Contributor
Hi Michael - Not at the moment, but we're working on two enhancements for an upcoming release that may help address this for you.
  1. Readers will be able to click any image to expand it
  2. You'll be able to adjust the width of the narrative panel for sidecar's docked layout
Another thing to consider is if you use the new floating panel layout of sidecar you can already adjust the width of the panels, which will make images larger.
Owen Evans
OwenGeo
Owen Evans
michael_vetter
Thanks for the reply Owen!
