Is there any way to use your own archival map with ArcGIS?
1029
11-06-2020 11:58 AM
OnaBantjes-Rafols
I'm new to using ArcGIS, and I am in the process of creating a StoryMap. However, when trying to add a Map Tour, I realized that I could only use the basemaps created by others. I have an archival map that I have permission to use, and I would love to create some kind of Map Tour using that, however it's starting to seem like that's not possible to do with ArcGIS?
OwenGeo
Esri Notable Contributor
Hello @OnaBantjes-Rafols -- Yes, that is possible, but I'm not sure of the specific steps. This is more of a question for the ArcGIS Online community.
Once you get your JPG images georeferenced and added to a web map, you'll be able to use that web map in a story.
Owen Evans
OwenGeo
Hi Ona Bantjes-Rafols‌ -- You can use a web map from your content—or one that you have access to through your organization—as a map tour basemap. Just click "Browse more maps" in the basemap picker and select the web map that contains your basemap.
Note that the web map basemap must be in web mercator projection.
Owen Evans
OnaBantjes-Rafols
I had found the "Browse more maps" button, yes. I have a scan of an archival map in my files (on my computer, as a JPG), and wanted to know whether there was any way to use that as a basemap with the options on StoryMap. Based on your response, I am assuming the answer is no?
OwenGeo
Owen Evans
OnaBantjes-Rafols
I'll try there, thank you!
