Is it possible to collaborate on a NEW story map with others in my organization?
2048
6
01-23-2020 08:16 AM
SharonJanzen
New Contributor III
I am working with a researcher who will have an assistant that will need to be able to edit a story map authored by the researcher herself. It doesn't appear the new story maps can be shared with a group that has editing capabilities...true?
OwenGeo
Esri Notable Contributor
Hi Sharon and John -- I looked into this, and this is currently the expected behavior. Granting other org members with update access via a group provides the other members the ability to make edits to the story, but not the ability to publish/share that story.
This is not a limitation with story maps, all ArcGIS items behave this way when shared to a group with update access. The sharing on an item can only be changed by the item owner (or org admins).
We plan to message this better in the ArcGIS StoryMaps builder a future release.
Owen Evans
OwenGeo
Sharon -- At this time, you can't do that from within the builder, as you've noted, but you can share a story to a group that has update capabilities in ArcGIS Online (for example on your Content page, or the group page) and it will work. You just have to manage the process manually.
Owen
Owen Evans
SharonJanzen
New Contributor III
Hi Owen,
While I am able to share to a group with update capabilities, members of that group are still not able to configure the story map...that's really what I'm after. I've added this to the ideas page. Hopefully it will get addressed with the next set of wonderful updates y'all come up with!
Sharon
OwenGeo
Sharon -- That's not the expected result. Can you provide some more detail about the specific steps you're going through to do this? Where does the process fail?
Owen Evans
JohnPlunkett
Hi Owen
I have come across this as well
Create group with update capability
Invite other member (creator/ publisher to group)
Owner creates a new story map and manually shares to group with update capability
Other member signs in to ArcGIS Online and opens story map in the group.
Clicks configure makes a change and then Publish
This error shows up.
I couldn't find anything in the network console that shows why we are getting this error.
However when you refresh the  storymap  the changes appear to have been made.
OwenGeo
Thanks for the detail, John. We'll look into this.
Sharon, is this the same issue you were seeing?
Owen Evans
OwenGeo
Owen Evans
