I want to create a main page for my story map application with language preference before entering the main application. I saw this and I will like to have it to make story map better. I need it ASAP. Thanks #ArcGIS StoryMaps
Solved! Go to Solution.
Hello -- There are a few ways to do this. Some simple ones that don't require custom code are described in the first blog post, below. If you are a developer and have the ability to download the Cascade source code, modify it, and host it yourself, you can consider the option described in the second article.
