How do you put scale bars into ArcGIS storymap
1341
04-27-2020 08:34 PM
Rishi_Doreswamy
I'm doing a story map for my final project and I want to know how do you put scale bars into the ArcGIS story map. I'm quite stuck on how to do it since there are no tabs I can use to get the scale bar to come into the story maps. My project is on the Australian 2019 bushfires and the rainfall deficit.
OwenGeo
Esri Notable Contributor
Hi Rishi -- That's not currently an option inside the new ArcGIS StoryMaps. However, you can use your map to create an app with a template like the Basic Viewer or Web AppBuilder, which do have this option, and then add that app to your story if you need to show a scale bar.
Owen Evans
OwenGeo
Owen Evans
Rishi_Doreswamy
Thank you,
I'm a freshman at college and my major is GIS.
I will try out your suggestion and see if that helps.
Thanks
Rishi Doreswamy
