Font not Displaying Correctly on Certain Monitors
1197
07-28-2021 04:28 PM
jp503
I'm using two different screens (one is part of my laptop, the other is external, specs below) and the font Klint in my StoryMap shows up incorrectly on my external and not the internal. All the specs seem to be the same sans the resolution. If I pull up the font in another window on a different site, it displays normally on both, so it seems to be a StoryMaps issue and not a monitor issue.
Normal Display:
Incorrect Display:
Screen Specs:
Resolution: 2048 x 1152 (internal) and 1920 x 1080 (external)
Refresh Rate (Hz): 59.9
Bit Depth: 8 bit
Color format: RGB
Color Space: Standard dynamic range
OwenGeo
Esri Notable Contributor
@jp503 -- Thanks for sharing this font display issue that you've encountered. Could you provide screenshots of the entire screen for both monitors? That would help us troubleshoot what might be going on.
Owen Evans
jp503
Here's a screenshot of the two side by side (the left is on my second monitor, the right is on the internal monitor from my laptop)
