Expanded images in sidecar fuzzy
228
7
2 weeks ago
Highlighted
Images in my sidecar are incredibly fuzzy/blurry. Is there a optimal workflow or image requirement when placing images in story maps? I have attached a video to show what I am seeing. The particular story map is my testing one so I cannot share it publicly, however, I can share it with a private group for troubleshooting purposes.
Thanks!
Highlighted
Esri Frequent Contributor
Hi @BryanHemmer  -- Thanks for providing feedback about this image quality issue. Are those PNGs? There is currently an issue with the ArcGIS Online back-end with serving out PNG images. We've heard that this issue should be addressed in the update coming in mid-Dec.
If you convert your original images to JPGs, do you still see the same issue?
Owen Evans
Reply
Highlighted
The images are both JPG's and PNG's, I used both to show it didn't matter. The caption below says what they are.
The original images are from Excel and I've tried to convert them using Word, Affinity Photo, and MS paint. But when placed in sidecar and expanded they all look the same, very blurry.
Reply
Highlighted
We can reproduce this issue. We'll look into this more and update this thread when we have additional info.
Owen Evans
Highlighted
Thank you for your assistance and quick reply Owen.
Reply
Highlighted
Hi Owen, I'd like to piggyback off of this same issue: we are having massive compression issues with images embedded in Sidecar in particular. When clicked to enlarge, nearly all of the images are compressed to the point of being illegible. This is a particular problem for us as we are showing archival manuscript documents with writing on them that are not legible at all. We have tried different file types and different sizes to see if that will help but nothing has. We are supposed to be launching our map in December and right now we cannot do that with it looking the way it does. Any update on this fix would be greatly appreciated.
Reply
Highlighted
@BryanHemmer @KateMcMahon -- This issue will be addressed in an update coming later today. Please check your stories tomorrow and let us know if you are still seeing this issue.
Owen Evans
Highlighted
Thanks so much for the quick turnaround!
Reply
