Bug with Nav links in StoryMaps
663
11-06-2024 05:58 AM
Labels (3)
MatthewBane
When using the slideshow sidecars and attempting to use nav links there seems to be a bug. If the slides in a sidecar exceed the height of the initial slide, then the nav links will not open to the the header, instead they will open to a second slide where the linked header should appear. This is difficult to explain, but screenshots below.
Each sidecar initial view uses a top level header to create a link (image 1). In my case, the second slide of the sidecars is longer. When clicking the second link in the nav header, it opens the second slide in the the series at the point where the second nav header should appear.
This is only with slideshow sidecar and is repeatable with all browsers.
ShaneONeill_144
I would suggest getting in touch with your local Esri Distributor, they can investigate this further for you
AbbyE_Esri
Hi @MatthewBane , I'm having trouble reproducing this issue with the screenshots. Would you be able to share a sample story where this is reproducible? To clarify, are you seeing the story open to the middle of the Camila slide instead of the top of it? Or is that screenshot actually showing it is accidentally opening the bottom of the Slam Anderson slide?
--Abby
ShaneONeill_144
