Embedded Credentials for Web Apps
933
05-18-2020 04:38 AM
Status: Closed
ZachStanford
New Contributor III
Currently, several dashboard applications I produce are shareable, but to controlled audiences. We embed dashboards into other systems which have credentialed access but would like to embed credentials into the URL, so users don’t have to login twice. Could credentials be added as a URL parameter?
Thanks!
3 Comments
JohnMDye
I understand the need here but I can tell you already, credentials in a URL is a really, really bad idea and is almost certainly not going to happen. The issue is that if you were to place credentials in a URL, they could easily be stolen.
Alternatively, you could go the route of just sharing the item with everyone which would mean you don't need to login to view the dashboard. Though, I assume you require authentication because whatever is in the dashboard might not be something you want anyone to be able to access.
In that case, you're unlikely to find a solution to this without implementing an shared SSO between the platform hosting the pages where you are embedding the dashboards and the ArcGIS Enterprise where those dashboards are hosted, and even that might not quite work depending on your configuration.
OwenGeo
Zach -- As mentioned above, this would circumvent the platform security, so this is not something that we'd consider.
If there is a set of people who need to see those dashboard you'll need to use the tools in the platform (sharing, groups, user accounts, etc) to provide those people with access to those content items.
OwenGeo
Status changed to: Closed
