2 of the 3 options when adding a Map tour are "Start from a feature service" or "Start with a feature service".
-"Start from a feature service" gives no possibility to add/edit text and image. I guess this is a simple way to avoid discrepancies between StoryMap and feature service but gives very limited possibilities.
- "Start from scratch" offers more possibilities/flexibility but each slide have to be filled in manually (image, Title, description and location). This is nonsense when we already have data.
It should be an alternative option that combines the advantages from both methods, the reuse of data from "Start from a feature service" and the flexibility form "Start with a feature service".
