If there is a route associated with a story map tour, it would be great to allow the creator of the story map tour template to add in a line file, whereas a line segment connects from point 1 to point 2, and so forth for however many points. If this can be possible for the story map tour template to have the ability to display directional arrows showing or highlighting the direction or route to the next point, this would provide an easy and effective way of communicating where the user should proceed to the next point of interest.
The classic Esri Story Maps templates are in extended support (read more) and are no longer being updated with new capabilities and features. We recommend using ArcGIS StoryMaps for all storytelling projects.
If your idea is not implemented in ArcGIS StoryMaps and you would like to request it be considered for a future release, please submit a new idea with the details of your request and how it would be useful to you and your organization.
