Modifying the appearance of a Survey123 form when it's embedded in a StoryMap
348
12-23-2021 07:25 AM
OwenGeo
Esri Notable Contributor
0 0 348
When you embed a Survey123 form in a StoryMap, the story builder makes some modifications to the form to try to make it look and work better in the story. Specifically, the navbar, footer, and theme of the survey form are hidden.
Many times these modifications are helpful, but sometimes authors might want to make different decisions. You can easily customize this behavior using the hide URL parameter. When you use the hide parameter, it will override the normal changes the builder makes with the ones you specify.
For example, if you want the theme to show but still want to hide the navbar and footer, you'd use a URL like this:
https://survey123.arcgis.com/share/abcd1234?hide=navbar,footer
If you wanted the navbar and footer to show but still strip out the theme, it'd be this URL to use:
https://survey123.arcgis.com/share/abcd1234?hide=theme
Essentially, just list the elements you want to hide and don't include the ones you want to show. For more information about Survey123 URL parameters, see this page of the Survey123 documentation.
About the Author
Owen is the lead product engineer on Esri's StoryMaps Team and is located in Esri's DC R&D Center in Arlington, VA. He's been with Esri since 2004, and was a Solution Engineer on the National Government Team until 2015. His main areas of interest are StoryMaps and Web GIS and his hobbies include hockey, tech/gadgets, and guitar.
