gp/arcpy scratch name methods can be very slow when the workspace in which you are generating scratchnames gets full of many files
#create scratch workspace name
tempDIR = "F:\\Data\\Reg09"
tempWorkspacePrefix = "update"
tempWorkspaceSuffix = 0
count = 0;
for raster in rasterList:
if count%30 == 0: # this is modulus operator, so should be true the first iteration and every 30 iterations thereafter.
tempWorkspaceSuffix = tempWorkspaceSuffix + 1
tempWS = tempWorkspacePrefix + str(tempWorkspaceSuffix)
if not arcpy.Exists(tempDIR + os.sep + tempWS):
arcpy.CreateFolder_management(tempDIR, tempWS)
out = tempDIR + os.sep + tempWS + os.sep
name = os.path.basename(raster).strip(".tif") # removes .tif from the file name
arcpy.env.cellSize = "MINOF"
arcpy.gp.ZonalStatisticsAsTable_sa(region, "VALUE", raster, out+name+".dbf","DATA", "ALL")
print" Raster " + str(raster) + " processing completed at " + time.asctime( time.localtime(time.time()) ).
count = count + 1
My python code is below....any suggestions on how to modify this code?
I should add that sometimes this script runs and sometimes not.
import gc
gc.enable()
os.path.basename(os.path.splitext(path)[0])
File "F:\Data\Reg09\attributetifsReg09.py", line 56, in <module>
<class 'arcgisscripting.ExecuteError'>: ERROR 999999: Error executing function.
Workspace or data source is read only.
Workspace or data source is read only. [The F:\Data\Reg09\update1\ workspace is read only.]
ERROR 010067: Error in executing grid expression. Zonal statistics program failed
Failed to execute (ZonalStatisticsAsTable).
We recently published a toolbox (first prize at the ESRI UC 2011 AppFair!) that includes tools that do overlap processing for statistics and area tabulations, among other things.
USGS Open-File Report 2010�??1268
National Water-Quality Assessment (NAWQA) Area-Characterization Toolbox
By Curtis V. Price, Naomi Nakagaki, and Kerie J. Hitt
http://pubs.usgs.gov/of/2010/1268/
The published version has only limited support for 10.x, but I have an updated version that will be posted there soon. If you are interested, let me know and I can send it your way.
> I am interested in checking out the tool for use with 10. Is it available on the web?
A version of the NAWQA toolbox that runs under 10.x is available in ArcGIS Online here:
http://www.arcgis.com/home/item.html?id=cbb59504f59f4e18b23817fb0ef40e56
Is there a link to an updated tool that we could download?
