What is the best tool to calculate the average distance?
3449
12-18-2012 11:51 AM
MisaYasumiishi
Hello, I want to calculate the avarage distance between multiple stores - such as the avarage distance between 20 chain stores in a state. I wonder what tool is the best tool to calculate it, if there is any ... Thank you!
DanPatterson_Retired
If it is road distance that you want, then you are going to need the Network Analyst extension
StefanHaglund1
Hi Misa,
I would use Generate Near Table with your stores as both input and near features and then perhaps Summary Statistics if you want your result in a table or just use the Statiscs... option on the column in the attribute table.
MisaYasumiishi
Dan, Stefan, Thank you for your input 😮
