Using Less Than & Greater Than in Raster Calculator
5562
11-01-2011 02:39 PM
FlemingTalton
Hello all,
I simply want to find the cells in a raster with aspect values between 225 - 315. I am using raster calculator with the following expression, for which I get an error that says "The truth value of a raster is ambiguous"
"Aspect_raste1" >= 225 & "Aspect_raste1" <= 315
What am I doing wrong?
thanks
CatherineMacGregor
Hi
I read a similar post the other day - apparently what you have to do is write the expression this way:
("Aspect_raste1" >= 225) & ("Aspect_raste1" <= 315)
Hope this helps.
