Raster to polygon problems
2189
04-25-2012 12:23 PM
grahamlangley-edwards
New Contributor II
Hi, I am trying to convert a raster to polygon in ArcGIS 10.  I initially used the Extract by Attributes tool to isolate elevation ranges between 1900 and 3800 meters from a 90m DEM.  I want to convert that into a polygon that I can use to clip an area of interest from some satellite tiles.  When I convert from Raster to Polygon I get a grid instead of a polygon (Screenshot2).  I also included an up close shot of the grid (Screenshot).  I'm not sure why this is happening.  The only options I have are to change the field parameter from Value to Count, but that also returns a grid structure.  How can I create a regular polygon from this data?  Any help is greatly appreciated....
Graham
by Anonymous User
Not applicable
Original User: dkwiens
Either:
1.) reclassify your raster so that all of the values between 1900 and 3800 have the same value, then convert the cells with that value to a polygon.
or...
2.) make a dummy column in the polygons you have now, make it equal the same value for all polygons, then Dissolve them all into one big polygon based on that column
New Contributor II
Darren,
Thanks for your reply!  I chose option 2, as it seemed a little more straightforward, and it worked perfectly.  I appreciate your time.
Thanks again,
Graham
by Anonymous User
Not applicable
Original User: curtvprice
Seems to me a more direct approach would to create a mask using the Set Null tool - and then use Extract By Mask. (No need to create polygons that way.)
As they say, raster is faster, but vector is correcter.
