Hi All,
I have a function I want to apply to a raster. I have multiple rasters, each will need this function applied. Here is the function:( 11.16 * Sin( FocalStatistics( "%Name%", NbrRectangle( 3, 3, �??CELL�?� ), "MEAN", "" ) ) / ( 0.765 + 2.625 * FocalStatistics( "%Name%", NbrRectangle( 3, 3, "CELL" ), "MEAN", "" ) ) ) / ( 11.16 * Sin( FocalStatistics( "%Name%", NbrRectangle( 3, 3, �??CELL�?� ), "MEAN", "" ) ) / ( 0.765 + 2.625 * FocalStatistics( "%Name%", NbrRectangle( 3, 3, �??CELL�?� ), "MEAN", "" ) ) + 1 )
As you can tell I have instigated 'iterate rasters' to get the %Name% input. I have this function currently stored in raster calculator within model builder. When I try and run the tool it crashes out saying that the raster does not exist.....it exists so obviously I am referencing it wrong inside of raster calculator but i don't see where I am going wrong. I am running 10.1.
I'mn have a similar issue... by output raster do you mean the output of the iterator or is that a tool on its own? I need to be able to select individual bands after many rasters have pulled into the model.
I mean the output of Iterate Raster.
Rather than pull multiple rasters into a model, it is usually much easier to go with the flow and process each raster in the iteration one at a time. You can select individual bands using the Select Data tool on each iteration.
I suggest starting a new, more specific thread if you want help with your workflow that involves extracting bands. Sounds complicated.
UPDATE: Never mind, I see you did: model builder to create NDVI
