Is it possible to do radiometric calibration on Landsat 8 using the raster calculator?
5473
02-17-2015 01:48 PM
GordonSeymour1
I am trying to sort out the most convenient way to perform radiometric calibration (to TOA reflectance values) on Landsat 8 OLI imagery data. I know it is fairly easy to do this using other applications such as ENVI, however I do not have this program at my disposal, so I was hoping I could do this correction task in ArcGIS (10.1).
I am already familiar with the formulas required to do this calibration manually, but am having a hard time trying to come up with a viable expression in the Raster Calculator tool.
Does anyone have an expression "template" I could use or work from? Any advice about this issue would be most welcome!
DanPatterson_Retired
what have you got so far as an equation
JeffreyEvans
Since the bands are quantized and calibrated, this is very straight forward for Landsat 8.
You will need a few band specific parameters from the scenes metadata. The scaling factors are standard so, once you have the band-specific values they can apply to any scene. However, this does not apply to the sun elevation, which is scene specific.
     Mp = REFLECTANCE_MULT_BAND_x (band-specific multiplicative rescaling factor)
     Ap = REFLECTANCE_ADD_BAND_x (band-specific additive rescaling factor)
     SE = SUN_ELEVATION (sun elevation angle)
Then, at-sensor reflectance is just a matter of some simple raster algebra in the raster calculator.
     ( Mp * Qcal + Ap ) / sin(SE)
where; Qcal = digital numbers (DN) raster of band n
JillKelly
The process is quite straightforward in Raster Calculator, but if you have already committed to the Composite Bands/Mosaic Dataset/Image Analysis window, it is completely opaque.  Raster Calculator doesn't work in that context, and while there are functions for "Apparent Reflectance" and -- inexplicably -- "Sentinel 1 Radiometric Calibration," it's not at all clear how one would put together such a function for Landsat.
