Contour lines not drawing
616
04-23-2012 04:39 PM
grahamlangley-edwards
Hello, I am trying to create a contour shapefile from a mosaicked DEM using ArcGIS 10.  When I use the Contour tool in Spatial Analyst, it creates a new layer but it does not draw.  When I Zoom To Layer it zooms out to 1:120,000,000 and still nothing is drawn.  Not sure what the problem is, if anyone has any suggestions I would greatly appreciate it.
Graham
Reply
SteveLynch
Try the following;
- CopyRaster( mosaic raster to raster (.img or fGDB or grid))
- Contour the above raster
Steve
Reply
Hi Steve,
Thanks for your reply.  I used the Copy Raster tool to create a new raster using the .img file extension, but the contour lines still would not draw.  I also tried the .asc and .gdb file extensions, but received an error saying that they were "Invalid for the output raster format".  I also tried to Copy Raster using .tif, but again it would not draw.  I've scoured the forums and can not find any info on this, any other suggestions?
Regards,
Graham
Reply
So I figured out that I just needed to reproject the DEM into the same coordinate system as the data frame, then the contour lines draw fine.  Hope that helps anyone else with the same problem...
Reply
