automate raster extraction and saving data based on input raster
2960
07-21-2014 11:44 AM
InceptionWoznicki
Hi ,
I have 70 raster files and I want to make 3 new raster from each of the 70 raster. For that, I want to automate the process using python script and store the output new raster based on the raster file name plus value field. For example, My input raster is  01367620-r-r and 3 value fields are 9,11, and 13. So the output folder should be 01367620-r-r-9. 01367620-r-r-11, and 01367620-r-r-13. When I ran my code, I got the below error message. I think, I am doing mistake at "outname=os.path.join(outws,str(i), str(j))" in my code. I would appreciate your suggestion/input.
Error Message:
  File "C:/Subhasis/Test/Neshanic_Python/Neshanic-test.py", line 23, in <module>
    attExtract.save(outname)
RuntimeError: ERROR 000875: Output raster: C:\Subhasis\Test\Neshanic_Python\extract\01367620-r-r\9's workspace is an invalid output workspace.
I am providing my code below.
import arcpy, os
from arcpy import env
from arcpy.sa import *
#To overwrite output
#Set environment settings
env.workspace = "C:/Subhasis/Test/Neshanic_Python"
outws="C:/Subhasis/Test/Neshanic_Python/extract"
#checkout ArcGIS spatial analyst extension license
arcpy.CheckOutExtension("Spatial")
# set local variable
inraster = ["01367620-r-r"]
for i in inraster:
    STI_list=[9,11,13]
    for j in STI_list:
        attExtract = ExtractByAttributes(str(i), "VALUE>=" + str(j))
Thanks!
XanderBakker
Esri Esteemed Contributor
If this question is related to the rasters created in your thread Re: loop for value and counts in raster attribute‌, then Dan Patterson‌ is absolutely right. The problem occurs in the line:
This should be:
outname=os.path.join(outws,"{0}{1}".format(i,j))
The first creates an outname of: C:/Subhasis/Test/Neshanic_Python/extract\01367620-r-r\9
The second creates an outname of: C:/Subhasis/Test/Neshanic_Python/extract\01367620-r-r9
The os,path.join will place a slash between each parameter. This causes the value "j" to be the raster name and the value "i" is interpreted as folder.
BTW: if the thread Re: loop for value and counts in raster attribute is solved, you should mark it as answered!
Kind regards, Xander
DanPatterson_Retired
The gist I get from that error message is that this folder ... C:\Subhasis\Test\Neshanic_Python\extract\01367620-r-r\9 ... doesn't exist and I think you need to create a raster object before using save
outname = Raster(os.path.join(outws,str(i), str(j)))
but I can't check... see ArcGIS Help (10.2, 10.2.1, and 10.2.2)
XanderBakker
This should be:
InceptionWoznicki
Hi Xander,
Thank you very much for your reply. I marked it as answer.
Regards,
Subhais
