ASCII to Raster output to 1-bit or 8-bit rasters?
2316
10
05-20-2011 01:28 PM
DaveVerbyla
I have some large ascii rasters output from models that are essentially 0 or 1 pixel values.
For example:
NCOLS 2
NROWS 2
XLLCORNER 0
YLLCORNER 0
CELLSIZE 1000
NODATA_VALUE 0
1 0
0 1
The ASCII to Raster tool outputs to a 32-bit signed integer raster, when really these values can be represented by a 1-bit raster.  Seems like an inefficient way to go!  Is there some other ASCII to Raster tool (in GDAL?, Python Imaging Library?) that is more efficient in importing ASCII data into rasters?
DaveVerbyla
The problem is this is inefficient using ArcGIS10...it creates a 32-bit raster when if it was
efficient, it would only create a 1-bit raster...
NCOLS 5
NROWS 5
XLLCORNER 0
YLLCORNER 0
CELLSIZE 1000
NODATA_VALUE 0
1 0 0 1 1
0 1 1 1 1
0 1 1 1 1
0 1 1 1 1
0 1 1 1 1
So far, looks like the best solution is to use GDAL outside of ArcGIS and output
to 8-bit rasters...
