"Copy Raster" tool result in 999999 error!!! why?
1829
05-25-2011 09:54 AM
by Anonymous User
Not applicable
Original User: Jamal432@gmail.com
please, see the attached images that show my question
explanation:
i used the tool "Copy raster" but i got the error 999999
what might be the reason?
thank you
regards
Jamal
curtvprice
MVP Alum
Hi Jamal,
The most common reason for this very generic error to happen is when ArcGIS finds something it didn't expect. I'm wondering if you may have been messing with the Value item in the raster table. It should never be set using table calculations. The way to get a field value from a raster table into the VALUE item is to use the Lookup function to make a new raster.
a thing I personally try to avoid is putting anything with a value outside 0-255 in a tiff, just for compatibility reasons with other software that reads tiff images that may or may not support something besides 8 bit integer values.
Is there a particular reason you want to push these values into a tiff raster?
