I am working in ArcGIS Pro 3.3 and with the Addressing solution. When I add a site address point, all my address points from the road centerline are odd values. The tool I am using is Site address end of line or driveway. It does not matter if the point is coming from the left or right side of the road. All my values that are generated are odd values. We have to manually change the values for the even side of the road.
Any insights would be greatly appreciated. The solution worked great when it was an add on for ArcMap and we just recently deployed it to ArcGIS Pro as part of an upgrade to ArcGIS Enterprise 11.3
Thank you in advance
John
Hi @JohnWatermolen_OCGIS, could you share some screenshots and additional details about the scenario. What is the address range on the road your are creating the address points for? What are some example of wrong address numbers being created?
