How do I edit the data for Election Results solution?
835
07-20-2020 06:51 AM
KimberlyRieger
New Contributor II
I'm looking for help editing the Elections Results solution now that it cannot be deployed using ArcGIS Pro. I deployed it by using the ArcGIS Solutions app in ArcGIS Online and it has my previous election data in it. When I try to add the features layers into Pro to edit them with new data for August, it cannot find them in the folder. Therefore I cannot add the feature layers into Pro to edit them. How do I edit the data for the solution?
MikeDagle
@KimberlyRieger Apologies it's taken so long to respond to this, Kimberly.
As you've most likely already discovered, a second deploy from the Solution App will get you new all new items. The Solution App looks in your contents for existing items to utilize. This is helpful when deploying a solution to take advantage of enhancements, but you'd like to utilize exiting data, however in this case you want new feature layers. Deploying a second time will get you everything.
Were you able to get the Election Results dashboard up and running?
KimberlyRieger
New Contributor II
Thanks for the response! Yes, I was able to figure it out and move forward with the Dashboard!
MikeDagle
That's good to hear. In case you haven't seen it I also wanted to point out our new site, specifically the enhanced Election Results documentation.
The Configure Election Results page contains a more thorough explanation of the feature layers:
https://doc.arcgis.com/en/arcgis-solutions/reference/configure-election-results.htm
