How to replace the legacy Geocode and Network Analysis (routing) services
3132
11-20-2015 04:24 PM
jitenderkumar
Hi Experts,
In our application we were using below mentioned routing services.
http://tasks.arcgisonline.com/ArcGIS/rest/services/NetworkAnalysis/ESRI_Route_NA/NAServer/Route
But is seems that this service got retired now.
When we are running the app and try to get the directions we are not getting anything.
Need you help to correct the application please suggest which service we should use now.
Regrads,
jitenderkumar
Hi Experts,
Need your help to resolve this issue.
Regards,
DeeleshMandloi
Hi Jitender,
   The replacement service is called ArcGIS Online Directions and Routing Services. Functionally the new service has a lot of improvements over the one you have been using. From the API standpoint, the new service is compatible. So Your app should be able to work with this new service with no or very little changes.
One major difference with the new service is that it is secured and requires an ArcGIS Online subscription to access. This means you need to buy a new subscription for ArcGIS Online and use the service credits that come with your subscription to access the service. You can evaluate if your app can work with this new service endpoint by signing up for a free trail of ArcGIS Online which comes with 200 service credits that can be used to access the routing service.
ArcGIS Online subscription is included with ArcGIS products. So your organization might already have an ArcGIS Online subscription. I would recommend contacting your local Esri account representative to dicuss further about ArcGIS Online subscriptions.
Hope this helps​
