In September we released ArcGIS Runtime Local Server SDK 100.9. This incremental update maintained the support for map and geoprocessing packages created with ArcMap at 10.8.x and incremented the support for packages created with ArcGIS Pro to 2.6.
In addition to providing compatibility with ArcGIS Pro 2.6, the release of ArcGIS Runtime Local Server 100.9 enabled support for several new and existing geoprocessing tools. The following tools can now be used in your models and scripts, packaged with ArcGIS Pro 2.6, and used with ArcGIS Runtime Local Server in combination with the ArcGIS Runtime SDK for .NET, Java, or Qt.
With the release of ArcGIS Runtime Local Server 100.9 we are also announcing some tool deprecations (matching their status in ArcGIS Desktop):
For more information see the following topics:
See the following topics for the complete list of ArcGIS geoprocessing tools supported for use with ArcGIS Runtime Local Server:
Several of these tools were enabled directly in response to your feedback here on Geonet and via Esri Support. If there are specific tools you would like to see enabled please let us know!
The ArcGIS Runtime Local Server Team
