ArcGIS Runtime Local Server SDK 100.10 is now available for download from the ArcGIS Developers site. This is an incremental compatibility release that provides support for geoprocessing and map packages created with ArcGIS Pro 2.7.x.
As previously announced, with this release ArcGIS Desktop 10.x packages are no longer supported with ArcGIS Runtime Local Server. The previous release, version 100.9, was the last ArcGIS Runtime Local Server release to support ArcGIS Desktop 10.x packages.
Note: If you are using ArcGIS Runtime SDK for .NET (Esri.ArcGISRuntime.WPF) you will need to update any projects referencing Esri.ArcGISRuntime.LocalServices from 100.9 to 100.10 via NuGet.org or alternatively download the package from NuGet.org to the local Esri NuGet source created by the ArcGIS Runtime SDK for .NET Visual Studio extension (%localappdata%\Esri\NuGet) and then update your projects.
ArcGIS Runtime Local Server is an optional component for the ArcGIS Runtime SDKs for .NET, Java, and Qt. It provides world-class scientific spatial analysis capabilities and data connectivity for your custom offline desktop applications. For more information please see the Local Server guide topics for .NET, Java and Qt.
We hope you’ll find these updates to ArcGIS Runtime Local Server useful as you continue to build amazing technology for your customers with ArcGIS Runtime.
